Author Topic: Front suspension  (Read 2118 times)
Offline Archie
Front suspension
« on: 11 March 2004, 09:43 »
Any known weaknesses or faults? I've noticed a sort of grating/creaking noise coming from the front n/s when cornering and braking whilst cornering. There are no obvious splits in the rubber gaiters and no other signs. Maybe a shocker on the way out?
Offline Starry
  • http://planetweed.co.uk
Re:Front suspension
« Reply #1 on: 11 March 2004, 16:58 »
if the cars been lowerd then it could be the drive shaft touching the anti roll bar. check for scoring around the d/shaft.
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
kniterider
Re:Front suspension
« Reply #2 on: 11 March 2004, 21:23 »
havent had any probs as such yet, but when i removed wheels to paint me calipers i saw a scuff mark on my drivers side drive shaft , mine must be catching when you push it hard as its lowered but the n/s is fine!!, i would check your drive shafts for any marks, if ok then maybe bottom ball joint ???
Gaz
