Cosmetic and bodywork matters
Lighting Modification
Topic: Lighting Modification (Read 1971 times)
Ashley
29 October 2007, 15:48 »
Had this posted in the mk3 section but only got 1 response.. hoping I'd get a better 1 in the right section!
I'd like to know if anyone here knows if it's possible to/how to wire up the original mk3 indicators with some indicators which are built into headlamps.. I'm pretty sure I've seen it done but I have no idea how I'd go about doing it..
Also whats the legality of this? I mean would this pass an MOT or would I need to disconnect 1 pair before it goes in?
...joe
Forum Supporter
Forum addict
Re: Lighting Modification
29 October 2007, 18:40 »
the ones you have seen are probably mk4 style headlamps, which have a built in indicator in the headlamp itself. legalitiy wise, i can't see that having two indicators on one side being a bad thing?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Ashley
29 October 2007, 19:16 »
The one's I've seen are kinda like the mk4's, but a different layout and smoked, I'll see if i can find a pic on here sometime later..
Will this affect the rate it indicators blink at etc?
AirCoolFool
31 October 2007, 21:58 »
If you connect up more than the standard number of bulbs then yes it will, unless you have a solid state relay. They're the same as the one's you use for LED side lights.
