Author Topic: Part No. help  (Read 1863 times)
Offline Grazer
Part No. help
« on: 28 October 2007, 21:29 »
Anyone know the part number for the oil temp sensor for a 1990 1.6 8v Driver?  :smiley:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Part No. help
« Reply #1 on: 28 October 2007, 21:38 »
doesnt have one?  :huh:
are you trying to fit VDO gauges?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Grazer
Re: Part No. help
« Reply #2 on: 28 October 2007, 23:03 »
As per pics here -
http://www.golfgtiforum.co.uk/index.php?topic=69265.0
Offline Dolly
Re: Part No. help
« Reply #3 on: 28 October 2007, 23:14 »
028919081D
oil pressure switch
0,25BAR M10X1 1 pin blue /
N 0138115
seal
A10X13,5 /
Offline Grazer
Re: Part No. help
« Reply #4 on: 28 October 2007, 23:18 »
Bloody 'ell!
You don't mess about there do you?
Thanks.  :wink:
Ps. Where did you get that info from?
« Last Edit: 28 October 2007, 23:21 by Grazer »
Re: Part No. help
« Reply #5 on: 29 October 2007, 09:39 »
thats a pressure switch.. for a pressure gauge.. not a temperature take off?
ive got a VDO sump plug with a temperature sender in the actual plug.. il get the company number i ordered mine from gloucester if you want it..
Quote
Offline Agreeable Slick
  • Unit
Re: Part No. help
« Reply #6 on: 29 October 2007, 14:02 »
have a look in the etka thread.
Offline Grazer
Re: Part No. help
« Reply #7 on: 29 October 2007, 14:15 »
I had a look in earlier, even registered with ETKA so I could have a better look at their site but it's not very clear, well to me anyway, which one i'm after.
I've removed the sensor and found that there was no "O" ring type behind it too.
On the back it states
0.15 - 0.45
0**919081C -  OB
  • Unit
Re: Part No. help
« Reply #8 on: 29 October 2007, 17:11 »
etka is a bit of a pain to use, if you don't know what you are looking for. That should be the same as the ones used across the board on all golf engines, have another browse through it, and see if you can find a part number for a sensor that has a .15-.45 bar rating.  :cool: they should cross over.
Re: Part No. help
« Reply #9 on: 29 October 2007, 19:05 »
dont you need a twinpole sender for fitting VDOs alex? and then a T piece or a sump temp sender.. due to resistance levels and shtoof.. and, well, what the senders are made for full stop?  :undecided:
Quote
