Author Topic: starting problems  (Read 1099 times)
Offline MK2 GTI REP
starting problems
« on: 28 October 2007, 18:08 »
1.6 8v ok well basically it has never started frst pop but always does with bout 2nd or third turn of the key .i had a vtr back box on it and with it it seemed to start alot easier.i have now got a hks one on it and it jus trys to turn over and eventyally starts .
Offline MK2 GTI REP
Re: starting problems
« Reply #1 on: 03 November 2007, 04:43 »
any ideas any1?
Offline dubslug
« Reply #2 on: 03 November 2007, 09:25 »
possible slight fuel problem??
1992 pearl grey 8v
Offline MK2 GTI REP
« Reply #3 on: 04 November 2007, 02:02 »
any ideas how to fix this the car is preigniting aswell running rich i know and problems starting how do i move on from this?
Leon R
« Reply #4 on: 04 November 2007, 12:54 »
If its pinking, get your timing checked. Cars sometimes struggle to turn over if the ignition timing is too advanced.
Offline takethefifth
« Reply #5 on: 08 November 2007, 18:26 »
You will need to check;
Your carb is set up properly and the cold start is functioning correctly
The electrical side is ok - ie. plugs, leads, dizzy, coil
Your engine timing
Details on most of this will be somewhere in the forum so have a search.
Good luck!
VeeDubGTI16v
« Reply #6 on: 08 November 2007, 18:40 »
is this hks exhaust a massive jap one? take that sh!t off!
« Reply #7 on: 09 November 2007, 17:26 »
sounds like a mk2 carby, check my 2e2 carb faq :)
