Author Topic: CAR CUT OUT TODAY 3 TIMES TOOK A WHILE BEFORE IT WOULD START  (Read 5561 times)
kells
Yep, once while driving and twice after id stopped and tried to restart it
id just fulled up at shell too
no flashing oil lights or anything strange just no spark
my mate from the main dealer is getting me relay 30 for 9am in the morn
hope that will sort it, got a busy w/end planned
drove fine all way home tho
Offline mattkh
Re: CAR CUT OUT TODAY 3 TIMES TOOK A WHILE BEFORE IT WOULD START
« Reply #1 on: 26 October 2007, 19:15 »
Hi
can you describe how it cuts out.
kells
« Reply #2 on: 26 October 2007, 19:36 »
Hi
only did it once whils moving, which was at about 30mph going accross a busy crossroads in leeds city centre, just basically saw the revs drop to zero as tho it had stalled..
then it decided it couldnt be arsed to start..it turned over but no spark, after 5 mins sat their trying it eventually started and was fine till i got to my next destination which was a place to book my car in for the Full stainless fitting, it then decided not to start again their too, after loads of trying and about half hour it fired up fine
got it back to work turned it off and tried it again, was the same didnt start, left it a hour then it was all normal
then when i finished work it didnt start but the second time i turned the key it was fine
Offline Pete Taylor
« Reply #3 on: 26 October 2007, 20:36 »
If the relay doesn't do the trick i'd look into maybe the coil next
kells
« Reply #4 on: 26 October 2007, 21:12 »
yep already thought that, its one or the other..
not sure how much coils go for??
Offline mattkh
« Reply #5 on: 26 October 2007, 21:35 »
Hi
When was the ignition switch last changed
kells
« Reply #6 on: 26 October 2007, 21:45 »
Hi
as far as i know never, id be annoyed if it was that, iv had cars done more than twice the mileage of this one and be fine haha
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 26 October 2007, 21:52 »
coils about £35-45 depending on where you buy.... allthough i would say its unlikely the coil as it seems your saying giving it a few minutes and all is fine and with the coil it would be worse in damp wet weather more than anything alse
Offline Pete Taylor
« Reply #8 on: 26 October 2007, 22:05 »
My ignition switch is knackered too. Luckily it's never effected the car, just doesn't switch off my stereo!
kells
« Reply #9 on: 26 October 2007, 22:06 »
i hear u boneyb....kind of thinking that also, although when i went to get into the car to come home, it did the non start thing but then with the key turned straight away again, it started fine, if u understand me...
it drove home perfect tho
getting relay with the number 30 on it tomo as my mate at the VW main dealer says thats what it will be as it did the same on his 16v
mad how its done this 3 times today and never before hinted at any probs...
