Golf mk3
hardmonkeys
Cockpit sounds like a Red Barron - possible the door has dropped!?
Topic: Cockpit sounds like a Red Barron - possible the door has dropped!? (Read 1870 times)
Lylos
24 October 2007, 16:03 »
Last one I promise....
When I get over 70mph it sounds like im in the cockpit of a bi-plane. The wind noise is incredible!
I'm unsure whether it's the seal on the car or whether the door has dropped slightly. Is this a common problem and does anyone know if it's fixable. it's getting quite annoying now so I would appreciate your replies.
Thanks
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: c*ckpit sounds like a Red Barron - possible the door has dropped!?
24 October 2007, 16:17 »
the heavy doors do drop and can be rehung quite easily (use the search function as someone quite recently ddid a write up on this)... but first check the seals are ok as these could be split etc
irmscher
Mobile Engine Tuning www.premiertuning.com
24 October 2007, 16:18 »
Check all your window seals and ensure the glass sits correct in it's place.
Can you hear the noise from a particular section of the car?
The doors do tend to drop on these cars, especially on the 3 doors. You can easily see by looking at how flush and level the lines are against the rest of the car.
You need a special Torx tool to loosen the catch bolts to adjust.
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com
or
Facebook
Len
10k hero
26 October 2007, 15:36 »
I had that problem and it was the door seal. Changed that and all quiet again!
www.sas.org.uk
www.the-ace.org.uk
boneybradley
Forum Supporter
Back in a Mk3...
26 October 2007, 21:59 »
hey i have a spare door seal if needed....
I keep finding mk3 golf parts everwhere....but now just have random stuff that i cant be assed to ebay
Lylos
29 October 2007, 22:06 »
Excellent, how much do you want for it mate?
boneybradley
Forum Supporter
Back in a Mk3...
Reply #6 on:
29 October 2007, 22:08 »
where are you based as its the post that'll cost!! unless you want snail mail??
east_sider
Just got here
Reply #7 on:
02 December 2007, 21:35 »
Mine's doing this as well, on the drivers side door, from 80mph and above, (sorry 65mph!!!!).
The door pins are clicking as well, so I guess I need to re-hang the door then? (3 door model).
What tool do I need, better to get a garage to do it?
Mikester
Forum addict
Civic Type R
Reply #8 on:
02 December 2007, 21:40 »
Mine is missing the plastic strip on the passenger door because of a dent, so i have loads of the small holes, so i get this loud wind noise over 60. Might check the seals too though. As it is loud for sure.
boneybradley
Forum Supporter
Back in a Mk3...
Reply #9 on:
02 December 2007, 23:17 »
my drivers door is giving me wind noise at higher speeds now!! i will have a look at rehanging the door and see what happens
Golf mk3
hardmonkeys
