Author Topic: MK3 16v less than perfect gear changing.  (Read 2090 times)
Offline eightyeightmph
« on: 23 October 2007, 08:32 »
Having now had the GTi for a while I'm getting bored just polishing it, I'm thinking it's time to start sorting out all the little 'niggles'. To that effect, the gear changing, although not sloppy, isn't as crisp as I'd like, it can sometimes be a little, resistant, but I have no idea what the cause/fix would be....
Would this sort of thing help matter?
http://cgi.ebay.co.uk/NEW-GEAR-SHIFT-REPAIR-KIT-VW-GOLF-MK3-1-8-2-0-GTI-TDI_W0QQitemZ320173184981QQihZ011QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Many thanks!
2016 GOLF GTD
Offline Len
Re: MK3 16v less than perfect gear changing.
« Reply #1 on: 23 October 2007, 09:07 »
That might do it, but when you say "resistant" is that in all gears or just certain gears at odd times?
www.sas.org.uk
www.the-ace.org.uk
« Reply #2 on: 23 October 2007, 09:47 »
Yes, pretty much randomly when I think about it!  :smiley:
2016 GOLF GTD
Offline RiCHiE360
« Reply #3 on: 23 October 2007, 09:49 »
Hate to worry you but thats what mine was like then a couple of months later it was in the garage havin a the gearbox recon'd!  :sick:
Roofless VR6 FTW
« Reply #4 on: 23 October 2007, 09:53 »
Uh-oh... how much did that set you back? It's nothing severe, as I said just a niggle really, selecting the gears is fine, it just feels 'awkward' around the shifter itself?!
2016 GOLF GTD
Offline RiCHiE360
« Reply #5 on: 23 October 2007, 09:59 »
Got quoted 450 for a rebuild alone.. Got a family friend where we take our cars tho and got a rebuild, new clutch, new speedo sensor, all for £420! It does feel incredible now tho.. Worth gettin it any niggles sorted with the box to stop any future expesive-ness!
Roofless VR6 FTW
Offline Pete Taylor
« Reply #6 on: 23 October 2007, 10:59 »
That kit will not work with your car. Your gearbox isn't about to blow up either. It's a common fault on the 02a boxes used in the Mk3 16V, the Mk3 VR6 and some Corrados. Because the box is cable change rather than rod change, the cables can slacken etc and they just need adjusting to counteract the possible synchromesh wear. If you get a used box, 9 times out of 10 it will have the same fault. Any vw specialist will have fixed this many times. There are no repair kits available for it now matter how hard you look
This is a guide on how to adjust..
http://www.houseofthud.com/shifting_gti.htm
« Last Edit: 23 October 2007, 11:04 by Pete Taylor »
« Reply #7 on: 23 October 2007, 11:05 »
Take it the 16V are cable then?
Cheers Pete.
Thank you all, sounds like I'd better put some money away for next month then! :rolleyes:
2016 GOLF GTD
Offline Pete Taylor
« Reply #8 on: 23 October 2007, 11:36 »
Yup 16v ABF use 02a cable change the same as the VR6, all other models of Mk3 and all previous versions of Golf use rod change. Look on top of your gearbox and you'll see the two cables going to the box
« Reply #9 on: 23 October 2007, 11:52 »
Pete, you are a legend Sir! Excellent news as Barclays would be less than impressed if they had to fork out for a refurbed box!! :grin:
Right then, I better have a read up & see if it's a practical DIYer!! Ta very muchly!
2016 GOLF GTD
