Author Topic: gti turbo timing belt change  (Read 5472 times)
Offline shawn
« on: 22 October 2007, 11:30 »
the wifes 2001 turbo (aum) needs the timing belt replacing and at the same time i'm gonna replace the water pump, has anybody took this job on themselves, if yes do i need any locking tools for the cams.
Any tips on the procedure would also come in handy. I have replaced belts before but they were on mk2 golfs and bmw e30's.
Offline Ridg
  • TDI - Soot Happens!
Re: gti turbo timing belt change
« Reply #1 on: 22 October 2007, 11:38 »
not done mine myself but i know richandhazel has on his TDI so might be worth dropping him a PM
Offline samy_1800_turbo
« Reply #2 on: 22 October 2007, 20:04 »
i did mine my self. theres marks to line up on 1 of the camshafts the other camshaft is driven by chain so youve only got to line up 1 pully i think its the exhaust. i couldnt find a mark or lock pin hole on the crackshaft so i marked it myself with tipex but i dont fink your surposed to do that  :grin: and to untensoin the belt you have to scew a bolt in the tension with a washer on it to untension the belt not sure wot size it is tho. the thing that p***ed me off the most was removing the engine mount doesnt seem enougth room to get it out  :angry: but it will come out eventaully. sorry i cant be more help.
Offline shawn
« Reply #3 on: 23 October 2007, 07:01 »
cheers for that,
 just bought a haynes manual and says bolt for the tensioner is a m5 threaded bar which you put a washer and  nut on and wind it down, and no locking tool is required for the cams.
 Bring on the grazed knuckles !!!
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #4 on: 23 October 2007, 17:27 »
You may also want to change the rollers whilst you're there, too!
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline shawn
« Reply #5 on: 24 October 2007, 23:56 »
sod it, rang the local vw dealer and they are doing a deal at the minute of £275.00 inc vat to fit timing belts and its an extra £75 for the water pump to be fitted, so its booked in for friday, saves my knuckles...
Offline Rhyso
« Reply #6 on: 25 October 2007, 08:12 »
why are they charging you an extra £75 for the water pump?? Water Pump is no more than £35 and it should be no more in terms of labour as its only three / 4 bolts i believe!
Tell them to rethink their quote; they're taking the urine
« Last Edit: 25 October 2007, 11:55 by Rhyso »
Offline Ridg
« Reply #7 on: 25 October 2007, 11:31 »
i'd get it down a local garage, as you can get the lot done with genuine parts for about £220 and its not like you can mess the cam belt up, it either works or it doesn't
Offline gsn1978
« Reply #8 on: 25 October 2007, 12:06 »
and if it doesnt then your looking handreds and hundreds to fix lol, i wouldnt take to the stealer though!! rip offs they have the belt off anyway and yes its a matter of a couple of bolts. :laugh:
Cheers, George.... 1.8 GTIt and loving it!!
Offline ub7rm
« Reply #9 on: 25 October 2007, 18:49 »
yeah, sounds like they are augmenting their admitedly cheap deal of timing belt change with an outrageously expensive (and I suspect heavily pushed) extra....
does the timing belt replacement price include the idler and tensioner or just the belt?
2020 BMW 128ti
2017 Golf GTD Estate
