Author Topic: Lay Flat Single Wiper  (Read 2286 times)
Fielder5757
« on: 09 March 2004, 02:48 »
Lay Flat Single Wiper front conversions.....What do yall think of them?
Offline Gambit
Re:Lay Flat Single Wiper
« Reply #1 on: 09 March 2004, 09:19 »
look alot better (when done correctly!) than the standard position
Blue MK2
« Reply #2 on: 09 March 2004, 09:51 »
makes the back end look more beefy than the old gay position. plus you know who is an enthusiast when u drive past other mk2 owners ;)
Offline DubFan
« Reply #3 on: 09 March 2004, 09:52 »
Single front wipers look ok, but in terms of practicality, not so clever because they have to wipe the same area as two wipers normally do and will miss out wiping the high spot that is in the driver's line of sight.
Blue MK2
« Reply #4 on: 09 March 2004, 09:53 »
Ive herd you can fit mercedes wipes to correct that? ^
Merc wipers are bigger
Fielder5757
« Reply #5 on: 09 March 2004, 12:16 »
Hmmm im giving serious consideration to shaving the wiper off the back, But i might just do the lay flat conversion. I dnno tho.
Blue MK2
« Reply #6 on: 10 March 2004, 08:59 »
fielder you should already have the conversion!
takes two seconds and cost nothing!
« Last Edit: 10 March 2004, 09:12 by Blue MK2 »
Offline jv
  • Administrator
« Reply #7 on: 10 March 2004, 12:49 »
some confoooosion here! Fielder starts talking about front single wipers then it goes into the rear wiper!
the rear wiper you can lay flat in about 2 minutes by removing the trim panel inside the boot and rotating the arm around.
front single wipers - i have one on my mk2 and like the much tidier look it gives. it does cover the whole screen very well and it has done all winter in rain and snow. the only problem is that it lifts off the screen slightly right in the middle of the screen. a new blade sorts it for a few weeks then the arm slowly bends it out of shape.
 :) jv
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Dizzie
  • Make friends with your fast
« Reply #8 on: 10 March 2004, 16:25 »
if you have a pre '88 mk2 you'll be use to having the top bit not wiped ;D
Mk4 Golf 150PD
Offline ASH
  • its a way of life!
« Reply #9 on: 10 March 2004, 18:11 »
heres how, did mine and changed it to a clio rear wiper.
http://www.gtiworld.fsnet.co.uk/wiper.htm
