Author Topic: torque to me?  (Read 1714 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
torque to me?
« on: 08 March 2004, 20:07 »
confused ???
I am torquing the head up on my 8v after replacing my head gasket but...
I read that it needs to be done in stages, in a specail order,  40n than 60n than a full half turn (180degrees)
I have done the 40n, and the 60n, which was the max settin on my wrench! But i only turned each bolt 1/4 of a turn (90 degrees) because that was as far as thay would go!
My question is, should i use (or need to use) a exstention bar and turn the bolts to 180 degrees ( an other 1/4 turn)
I know i should follow the manual but it seems like ALOT of force to me?????
HELP any one???? :(
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
golfvr6
Re:torque to me?
« Reply #1 on: 08 March 2004, 20:19 »
YES!!
Get a longer bar, you will need to do the bolts up to the specification. And yes the bolts are bloody tight!
Offline davidhawkins_78
  • Valver Bad Boy
Re:torque to me?
« Reply #2 on: 09 March 2004, 12:56 »
I'll agree with VR6 here - one thing though .....
If you've used non VW parts be careful as when torquin the bolts they can snap as they don't stretch in a uniform manner (Cheap materials).
Just go slow and easy ....
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
golfvr6
Re:torque to me?
« Reply #3 on: 09 March 2004, 14:06 »
If the bolts won't go to the full tightening without snapping then the head won't seal anyway. Torque it up!! the vr6 headbolts needed a 2.5 ft bar to do them up, they were f**king tight!
Offline gti fly bye
Re:torque to me?
« Reply #4 on: 09 March 2004, 16:23 »
cheers, this job is takin for ever, only got the weekends, roll on the summer, cheers again ;D
golfvr6
Re:torque to me?
« Reply #5 on: 09 March 2004, 17:20 »
Take your time, do the job by the book, otherwise it will blow again.
