Cosmetic and bodywork matters
Rubbing down
Topic: Rubbing down (Read 2254 times)
dubsport
TDI POWAR!
Rubbing down
19 October 2007, 19:40 »
when rubbing down spoilers and boot plinths ready for spraying is it best to rub it down so its totally smooth or do i 'key' it so the paint holds?
thanks
dubsport
TDI POWAR!
Re: Rubbing down
21 October 2007, 14:05 »
anyone?
Grazer
GTI forum regular
Re: Rubbing down
21 October 2007, 22:59 »
A good "keying" should do the job.
I'll be doing the same thing shortly with my new boot/grille spoiler and support.
Conker
Re: Rubbing down
22 October 2007, 09:19 »
I did a little bit of rattle can spraying the other week and I keyed the surface with wet and dry, then anti-rust primer (which fills all the scratches), then
very
fine wet and dry, then top coat.
Worked a treat.
Grazer
GTI forum regular
Re: Rubbing down
23 October 2007, 01:04 »
I usually try high-build primer for the minor scratches and imperfections.
Rubbing down
