Author Topic: Stuck  (Read 1273 times)
Offline RiCHiE360
Stuck
« on: 19 October 2007, 02:29 »
How do i get the clocks out of ma dash lads?
Roofless VR6 FTW
Offline RiCHiE360
Re: Stuck
« Reply #1 on: 19 October 2007, 12:59 »
Anyone?  :sad:
Roofless VR6 FTW
Offline boneybradley
  • Back in a Mk3...
Re: Stuck
« Reply #2 on: 19 October 2007, 14:20 »
I have got pictures but im having trouble uploading them as my card reader has given up!! I will take more by phone and upload this weekend!
Offline RiCHiE360
Re: Stuck
« Reply #3 on: 19 October 2007, 15:47 »
LEGEND!  :smiley:
Roofless VR6 FTW
Offline Pete Taylor
Re: Stuck
« Reply #4 on: 20 October 2007, 13:31 »
MK3 clocks right? Well....
First take off the dash blank to the right or your stereo and take the screw underneath it out.
Take the two screws out from under the ignition cowling and removed that.
Take out the far right air vent above the headlight switch and take that screw/screws out.
Remove the airbag/ABS warning light and unplug.
Removed headlight switch and unplug.
Remove screws from behind where the headlight switch and airbag/ABS warning lights were.
Pull out the clock surround.
The clocks have two screws holding them in, remove the screw either side at the top.
The bottom of the clocks are just hinged, pull them towards you and the bottom pops out.
Remove plug from back of clocks and remove clocks.
If you're changing the LEDs then you'll see two metal strips across the top of the dials with two twist in LEDS sticking out.
If your wanting to get into the clocks then there are white clips all around the outside that need unclipping.
Hope this helps!
Offline RiCHiE360
Re: Stuck
« Reply #5 on: 20 October 2007, 15:54 »
Cheers for that pete! Got them off, was quite simple when you know how..
How did ou get your heater controls lit up so well by the way?? Cheers
Roofless VR6 FTW
Offline Pete Taylor
Re: Stuck
« Reply #6 on: 20 October 2007, 16:11 »
They're not mine :P Guy called vento jim from another forum did them
Offline RiCHiE360
Re: Stuck
« Reply #7 on: 20 October 2007, 16:17 »
God dam it!! Ill get mine like that one day soon  :sad: haha  :grin:
Roofless VR6 FTW
Offline Pete Taylor
Re: Stuck
« Reply #8 on: 20 October 2007, 16:18 »
Pretty easy to do, I've just not got round ton finishing mine, still working my way through the switches VERY slowly
Offline RiCHiE360
Re: Stuck
« Reply #9 on: 20 October 2007, 16:21 »
Iv done all switchs apart from the headlight one which u obviously cant do.. And iv custom fitted 4 blue leds in my heater dials behind the cover which looks mint but the ones you posted are actually perfect!  :shocked:
Roofless VR6 FTW
