Author Topic: Fog Lights How to  (Read 3081 times)
Offline colourcongti
Fog Lights How to
« on: 08 March 2004, 11:26 »
Does anyboy kknow how easy it is to install front fogs on a MK3 or is there a how to guide any where that i can look at thanks
Offline Cupra Turbo
Re:Fog Lights How to
« Reply #1 on: 08 March 2004, 11:32 »
[size=12]Your In Luck![/size]
I just installed Smoked fogs/indicators in my Mk3 ... so If ur car has fogs already and ur doing what i did (putting different ones in) then here u go
Use Screwdriver to pop off the blank plate thing
onto the foglight, unscrew two screws and then lever the small metal clip on the right side, with screwdriver. Fog light falls out.
take cover off actual fog unit ... disconnect the power of course.
remember not to touch the lens ...
it all goes back in the same way, but in reverse order.
if u DONT have fogs... then I aint got a clue how to wire em up, sorry.
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
« Reply #2 on: 08 March 2004, 11:36 »
thanks 4 that mate but its the full job i need wire the lot
Offline Cupra Turbo
« Reply #3 on: 08 March 2004, 22:29 »
search google.  ;D
Offline richellis
« Reply #4 on: 14 March 2004, 11:43 »
i did this on my mk3 TDi. Got the lights, blancking plates, and a switch. You then need the wirin loom. Not as bad as it sounds! There is a large connecting plug at the front of the engine bay (top left of the rad as you look at the car) Undo this and remove. This includes the headlights, indercators, and the horn I think. Then replace with a new loom  from a car with fogs, replace the switch et-voila!!!
Took less that an hour!
« Last Edit: 14 March 2004, 11:44 by richellis »
MK3 Golf GTI
« Reply #5 on: 15 March 2004, 11:10 »
right now have lights and switch anybody know where i can get a loom from been down to scrap yard but none have fog lights
Offline richellis
« Reply #6 on: 15 March 2004, 14:18 »
Got mine from midland vw, but any special vw breakes should b able to help. U cud try vw? dunno how much tho
MK3 Golf GTI
Offline Overseer
« Reply #7 on: 15 March 2004, 14:48 »
* Overseer just ordered smoked fogs.. fitting this weekend
Offline Overseer
« Reply #8 on: 16 March 2004, 09:41 »
btw
vw smoked fogs/ indicator/blanking plate.... estimated at over 360 quid (gave up in vw once the price went over 350..)
got mine for 99 quid from  http://www.venommotorsport.com (found em in performance vw)  bargain!!
« Last Edit: 16 March 2004, 09:45 by Overseer »
