Author Topic: Problem SOLVED section - sub section?  (Read 4694 times)
Offline GuvGTI
« on: 15 October 2007, 11:20 »
Came to my attention when trying to search for an answer to a problem i had with the car. First thing was to search.... LOts of questions came up about the problem but not many threads showing how they solved it! Or some giving not so accurate answers.
Just a thought maybe in the maintance section or in the garage section. Have a problem solved section. With tried and tested methods giving the required results for instant look up and read!!
For example
Problem 1: Mk3 GTI ABS sensor on
Solved: first cleaning sensors located here, then if not cured attach to vag come and locate sensor etc etc etc.
Problem 2: Mk 2 GTI
Solved:
etc.
What do you rekon?
Offline Len
Re: Problem SOLVED section - sub section?
« Reply #1 on: 15 October 2007, 12:31 »
The major occurring faults are usually to be found in either the Sticky section or Maintenance!
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 15 October 2007, 13:18 »
I know the same questions get asked time and time again...and i sticky the relevant answers if not all ready stickied, if you do find something that should be stickied try pm'ing the relevant section mod and ask them to sort it??
at some point i will go through the mk3 sections and merge/sticky any decent answers and clean the place up a bit.. should make searches easier??
Offline GuvGTI
« Reply #3 on: 15 October 2007, 13:31 »
kool mate, sounds good. Wasnt trying to comment on your work there mate!!!! dont think i was doing that to you. I will let you know.
