Author Topic: heater control lights not working  (Read 1658 times)
Offline mark j b
« on: 15 October 2007, 10:44 »
in my 94 mk3 the heater control lights have never worked does anyone know how to fix this?
Offline miyagigoose
Re: heater control lights not working
« Reply #1 on: 15 October 2007, 10:47 »
If its the ones around the heater switch id suggest removing that part from the dash and changing the little bulbs maybe?
Offline RiCHiE360
« Reply #2 on: 15 October 2007, 11:19 »
Your bulb will have either blown or come loose (there is only one bulb) if you use a small screwdriver to pop off the cover around the dials there are four phillipsscrews, remove them and then slide out the ash tray and remove the 2 screw there and the heater control unit will slide down, on the back there is a white piece of plastic in like a half circle, unclip theis and replace bulb. Really easy  :smiley:
Roofless VR6 FTW
Offline mark j b
« Reply #3 on: 15 October 2007, 12:49 »
thanks richie i got the bulb out and its blown.so should be an easy fix.does anyone know if the bulb is the same size as the ones in the dash clocks or could i replace it with a blue led?
Offline RiCHiE360
« Reply #4 on: 15 October 2007, 13:03 »
I replaced mine with a blue LED from ultraleds.co.uk
Although after a couple of hours work iv added an extra 3 wiring looms so i have 4 Blue leds in drilled holes behind my light up display.. Worth every minute.. Just need a steady hand, Patience and a mate help you with the in car soldering haha  :laugh: :grin:
Roofless VR6 FTW
Offline mark j b
« Reply #5 on: 15 October 2007, 13:05 »
did you add more because it wasnt bright enough?or some other reason?
Offline gtianniversary
« Reply #6 on: 15 October 2007, 13:11 »
Thanks for posting that, it saved me the time! Mine has gone aswell and also now the bloody right side dash light has gone! i cant see how nuch fuel i have got when its dark! Any pointers??? Thankyou in advance!
Offline mark j b
« Reply #7 on: 15 October 2007, 13:31 »
if you take the clocks out there is bulb holes at the top simple fix.to get them  out pop off all the blanking plates and take the screws out
Offline RiCHiE360
« Reply #8 on: 15 October 2007, 13:37 »
Yeah i did it becuse there so incredibly dim.. Even with a superbright wide angle Blue LED. It works/looks amazing now, was worth the extra effort!
Iv got the bulbs for the dash/speedo now just unsure how you get the dials out.. any ideas or anyone know of a "how-too" thread on here?
Roofless VR6 FTW
« Reply #9 on: 15 October 2007, 13:56 »
I am gonna be busy tonight with my screwdriver! Cheers for that!
