Author Topic: Headlights  (Read 1193 times)
Offline ub4_dub
Headlights
« on: 14 October 2007, 16:04 »
Hi has anyone taken the glass covering of the headlamp and if so is it just clipped on or isit clipped and glued also was not sure if someone could help?
kells
Re: Headlights
« Reply #1 on: 14 October 2007, 16:25 »
mine seems to have glue also altho iv now put a twin headlight conversion on
was gonna put halo rings into my oe lights but thankfully decided it was too chavvy hehe
Offline boneybradley
  • Back in a Mk3...
Re: Headlights
« Reply #2 on: 14 October 2007, 16:44 »
they are clipped and sealed on.... use some silicon seal remover if you really need to remove as resealing dosent all ways work well!!
Offline eightyeightmph
Re: Headlights
« Reply #3 on: 23 October 2007, 09:46 »
Have recently done this, the glass is held on with a putty type substance albeit VERY well stuck. I found the glass can easily chip if you lever against it....
I took a stanley knife & carefully pryed away between the glass & plastic removing as much of the putty as possible then got a flat edged screwdriver & worked it in between, making sure that any 'leverage' was on the plastic. once it was in I carefully worked around the whole light until the glass came free.
Hope that helps!
2016 GOLF GTD
Re: Headlights
« Reply #4 on: 23 October 2007, 09:49 »
Could of sworn I took a pic, but I'll be damned if I can find it!
The plastic almost wraps around the glass, like a lip that the glass sits on so you have to 'wiggle' the screwdriver to get it under the glass!
2016 GOLF GTD
  • Back in a Mk3...
Re: Headlights
« Reply #5 on: 23 October 2007, 09:55 »
thats that grey mastic type rubber non setting stuff!! awfull stuff to remove!!
Offline CraigDavid
Re: Headlights
« Reply #6 on: 23 October 2007, 10:00 »
They would have to sealed otherwise condensation/water would gather inside the lens!! Vise-Versa they will need to be re-sealed thoroughly to prevent water gathering inside!!
