Author Topic: RE:ABS / Brake problem  (Read 3746 times)
Offline CSB-GTi
« on: 12 October 2007, 19:07 »
Recently changed pads all round on my GTi, the pads have been well bedded in although the rears were a little sticky. I am now getting a vibration and a grinding sound back through the brake pedal when a small amount of pressure is applied or light braking, if a heavier pressure is applied it is fine.
The system has been bled and the braking fluid level is fine.
Anyone experienced this before?
cheers
Offline Pete Taylor
Re: RE:ABS / Brake problem
« Reply #1 on: 20 October 2007, 14:06 »
If you didn't change the discs then it could well be the new pads bedding themselves into the shape of the old discs. If you've been a right numpty then maybe you put one the the pads on the inside the wrong way round!
Offline CSB-GTi
« Reply #2 on: 30 November 2007, 16:14 »
Hi All,
FYI, this turned out to be a broken ABS ring which is part of the Hub assembly.
all fixed!
Offline Pete Taylor
« Reply #3 on: 30 November 2007, 16:16 »
and your ABS was still working?
Offline Len
« Reply #4 on: 30 November 2007, 16:30 »
Couldnt have been could it! he didnt mention the ABS light, but then somebody has probably taken the bulb out! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Pete Taylor
« Reply #5 on: 30 November 2007, 16:31 »
Well if it doesn't come on for 3 seconds when you switch the ignition on then there's definately something wrong..
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #6 on: 02 December 2007, 14:15 »
sometimes when i start mine from cold there is a 5 sec vibrating sound (i can also feel it through the floor) coming from behind the dash or bulkhead, anyone know what this might be my car is a 8v completely standard.
many thanks
dan
Offline Pete Taylor
« Reply #7 on: 03 December 2007, 11:02 »
If you park the car up a kerb or at an angle it's probably the exhaust knocking. A rubber gone or a mount broken
Offline G60GTI16V
« Reply #8 on: 03 December 2007, 13:41 »
no its nothing like that, (i am quite mechanical) it sound like some sort of motor or something just going brrrrrrrr for about 5 secs its quite a strong noise, movement to be exhaust ect. only happens sometimes when started from cold/after parked up for the night.
many thanks
dan
Offline Pete Taylor
« Reply #9 on: 03 December 2007, 15:54 »
Sticking starter?
