Author Topic: gearbox  (Read 2674 times)
Offline Danr
gearbox
« on: 07 March 2004, 14:11 »
Im interested in gaz`s gearbox if its for a 16v but he is not sure if its an 8 or 16, whats the differences, any tell tale signs on em or whats the part numbers on them?
cheers dan
Blue MK2
Re:gearbox
« Reply #1 on: 07 March 2004, 14:31 »
if you have an 8v engine wouldnt a 16v box be a bonus? speed wise ???
« Last Edit: 07 March 2004, 14:31 by Blue MK2 »
kniterider
Re:gearbox
« Reply #2 on: 07 March 2004, 14:42 »
dont think will help speed wise, i think the 16v gets its speed cause it revs higher than the 8v, but what would i know!! lol he he ??? come on gotta be some one who knows how to identify difference ei part number etc and where to find??
is rich out there?? he's the gearbox man!!
Offline richandhazel
Re:gearbox
« Reply #3 on: 07 March 2004, 14:56 »
I'm here ;)
The ratio's are obviously different to match the different characteristics of each engine. I don't think there is any advantage to be gained by sticking a 16v box on an 8v engine, but I stand to be corrected.
I'll have to delve into my ETKA to find you the part numbers, which may take a while as its not working at the moment, for some unknown reason. I'll have a quick look in my Bentley and see what that says.
Re:gearbox
« Reply #4 on: 07 March 2004, 15:03 »
Ok, got something for you..........5 minutes and I'll have a chart uploaded
Re:gearbox
« Reply #5 on: 07 March 2004, 15:06 »
Here you go, hopefully this will help:-
Offline mk1
Re:gearbox
« Reply #6 on: 07 March 2004, 17:57 »
The 16v and 8v 020 gearboxes are interchangeable, the 16v uses a larger input shaft so you have to use a 16v clutch. They are said to be stronger  ???.
Steve.
Offline Danr
Re:gearbox
« Reply #7 on: 07 March 2004, 19:44 »
So whatever gearbox i put on my 16v mk2 wont really matter then?
Re:gearbox
« Reply #8 on: 07 March 2004, 20:42 »
Well it'll work, but as Steve says, you will have to match the clutch with the gearbox as the splines are a different diameter.
Offline Danr
Re:gearbox
« Reply #9 on: 07 March 2004, 23:02 »
Well the garage near me said they will trake mine out and fit a new one for 105 so am trying to geta gearbox now, was gonna do it myself but my mk1 needs some work doing on it now due to idiotic drivers  >:( so need a car on road, as am being sulked at for having to broke cars now  ;D
