Author Topic: 8v judder/stutter/ have tried the common fixes! solved  (Read 1720 times)
Offline GuvGTI
I have searched quite thoroughly, but to no avail at the moment.
I until wednesday the car seemed to judder and stutter in the range of 1000-2200rpm when i put on the accelerator, holding revs didnt cause it. This must have an effect and hence loss of power. Not sounding smooth.
I have been to VW parts and bought and changed.
167 fuel pump relay
30 ecu relay
cleaned the throttle body with carb cleaner to best ability
cleaned and checked breather pipes
bought and changed the temp sender part number w6u0 919 501 b
all have no effect possibly slightly better but Its still present now!
Any ideas? its getting annoying now.
thanks
« Last Edit: 15 October 2007, 00:45 by GuvGTI »
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: 8v judder/stutter/ have tried the common fixes! whats next?
« Reply #1 on: 12 October 2007, 15:42 »
Is it missing?  Have you checked your HT leads?
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline GuvGTI
« Reply #2 on: 12 October 2007, 15:58 »
all the leads seem fine to me. just had a look. yeh it seems to missing. i can only decribe as juddery and not smooth.
Offline Horney
« Reply #3 on: 12 October 2007, 16:02 »
Get some Puka VW leads as I have found other brands to be rubbish. 1 set I got failed on the first run!
Nick
Offline GuvGTI
« Reply #4 on: 12 October 2007, 16:04 »
thanks irmscher and horny will look into it!
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 13 October 2007, 10:08 »
guv could be worth checking the coil too....these can be a fault if they crack
Offline GuvGTI
Re: 8v judder/stutter/ have tried the common fixes! solved
« Reply #6 on: 15 October 2007, 00:47 »
got a compression test done, had the full engine checked aswell. I think i should next time think simple instead of jumping to conclusions. Changed the spark plugs and leads and all was ok, put some injector cleaner in the petrol and gna stick with super unleaded, bp ultimate v power etc now.
