Author Topic: crap heater!  (Read 6504 times)
Offline Horney
Re: crap heater!
« Reply #10 on: 08 October 2007, 16:22 »
Heater matrix change? Cheaper and less hassle to buy a decent coat and gloves. I did one a few years back and it was the worst job I've ever had to do on a MKII. I ended up having to source loads of bits frm the scrappy as the box with all the flaps in for directing the air just fell to bits when I took it out. VW wanted £150 for a replacement!
Nick
Offline jammac
Re: crap heater!
« Reply #11 on: 08 October 2007, 16:31 »
GREAT! im filling with confidence now!
ive just bled the system as per R.Js guide. hasnt seemed to have done much at first glance but i guess i wont know until i start her up from cold as to whether or not its worked? rad flush tomorrow anyway i think as my coolant is looking pretty brown!
ITS A TRAP!
Offline Horney
Re: crap heater!
« Reply #12 on: 08 October 2007, 16:34 »
I think mine went as wrong as it's possible to go, they're not all that bad.
Nick
Offline jammac
Re: crap heater!
« Reply #13 on: 09 October 2007, 14:04 »
OK i think its safe to say bleeding the system has done naff all as i had to drive home from a nightshift freezing my arse off this morning!! ill get on with the rad flush when its not raining.
ITS A TRAP!
Offline Ben Lessani
Re: crap heater!
« Reply #14 on: 09 October 2007, 20:58 »
The bypass valves look like this...the lower left corner with the u-shaped pipe and jubilie clips on it
then after you remove them, if will look something like this....to the right hand side of the rocker cover, the two copper pipes
Offline Organisys
  • Old and Slow...
Re: crap heater!
« Reply #15 on: 09 October 2007, 21:18 »
Flush the matrix in reverse direction. Find a mechanic with a pressure stream cleaner of you can.
Search Ebay for cheap coat as Nick mentioned. Leave coat in car, job done.
 :smiley:
Offline clipperjay
Re: crap heater!
« Reply #16 on: 09 October 2007, 21:54 »
Can you buy like an electric fan that plug into the ciggie and bingo instant heat no need to wait for the car to warm up either! :laugh:
J
Offline Ben Lessani
Re: crap heater!
« Reply #17 on: 09 October 2007, 22:09 »
Trouble is electric heaters draw a few hundred watts of power, usually 500+ ..... a good 40 amps of power, might melt the poor quality ciggy wiring.
Offline clipperjay
Re: crap heater!
« Reply #18 on: 09 October 2007, 22:11 »
Yeah I was taking the pisss fella  :wink:
Offline Dolly
Re: crap heater!
« Reply #19 on: 09 October 2007, 22:38 »
mine is luke cold at best its the stat.. its open all the time hence longer warm up times and heater times.. it sits halfway between a quater and half driving and takes an eternity to get there.. if i sit idle for 10 mins and it finally hits halfway (normal operating temp) the heaters work fine.. ill see how it goes when i put a G60 in with a working stat in the baby
