Author Topic: crap heater!  (Read 6514 times)
Offline clipperjay
Re: crap heater!
« Reply #40 on: 16 October 2007, 11:28 »
HEY!
I flushed my coolant system with that holts 2 part flush stuff and guess what!?!?
it has made a little bit of a differance! and my engine temp is about 4-6 degress less!!!
still not hot enough to de ice my windscreen at 6am in the morning in january though, so i guess the inevitable is here!!! ill hang back for your picy guide though clipperjay! thanks for your help mate!
I did my flush twice..... I think cascade problems cause meno end of grief, but  a car that has sat for 10 years in a barn I'm not surprised. Its grief doing this job I'm waiting for the delivery of the new rad can't carry on until then. Bloody postal strike! My problems is defo blocked heater matrix the massaging of the pipes I did ended up pooping the blocked rad.
You are using de-ionised water arent you, after flushing? keeps it nice and clean no lime scale to bugger it up again.
J
Offline moimo
Re: crap heater!
« Reply #41 on: 16 October 2007, 21:15 »
the heater matrix from new was always an issue, the tempreture and the combination of pressure caused as people know the matrix to go which as we all know is a pain in the rear end to change, a mod/recall was insigated and this is the heater bypass valve which allows water to circulate round the system bypassing the matrix, irstly if your car hasnt got one its very easy to tell, the inlet and outlet that go through the bulk head will be straight pipes and nothing attached, if the is one it will consist of a metal valve a plastic cylinder and it will be connected between the in and out for the heater matrix under the bonnet as shown by photos alreayd posted. as the valve gets old it stops allowing water to circulate through the heater matrix and only acts as a bypass hence the purpose. unless you are a real gambler i would replace as a matter of course when ever you by a car, its the equiv of changinf the cam bel to stop valve damage, they are about 30.00 last on i got from gsf, oem vw part as thats the only people who make them (some one may have started but for 30 quid get the quality one). hey take about 10 mins to change an if you have no leaks in your system and the engine is hitting normal temp this is hat it will be, i would strongly advise against running with out one, that said people have done for years and thee will be lots of golfs that have never had one. anyway a lot of waffle
basically, change the valve when you change yr car, rember check antifreeze mixture especially this time of year, hope hats of help Mo
Offline dubmaster77
  • actualy on the road!
Re: crap heater!
« Reply #42 on: 16 October 2007, 22:50 »
I have changed my matrix valves and thermostat, Now i get a rweading on the temp gauge but still no warm air through my blower!!! Gutted!!!!!11 Im losing patince with it fast!!!
K-Jet is my friend!
Offline golf8v
Re: crap heater!
« Reply #43 on: 22 October 2007, 20:08 »
get rid off the bypass valves they were my problem. now i have lovely heat..
Offline FAZAT
Re: crap heater!
« Reply #44 on: 15 November 2007, 15:02 »
Just thought I would BUMP this tread as I have no heaters at the mo.
But I now have a list of things to try :cool:
