Author Topic: Mk4 Golf rear callipers, Bora?  (Read 708 times)
Offline Dolly
« on: 06 October 2007, 16:47 »
after being let down with a set of mk4 rear callipers ive found a set from a BORA year 99 also advertised as Audi A3 fitment... simple question ... are these the same as Golf Mk4 callipers and the same straight swop onto the mk2 with the adpter flexi hose and longer cables ?
Offline pegasus
Re: Mk4 Golf rear callipers, Bora?
« Reply #1 on: 06 October 2007, 18:11 »
i would say yes, exactly the same.
1.8 20VT GTI
Offline Gambit
« Reply #2 on: 08 October 2007, 15:07 »
seconded
« Reply #3 on: 10 October 2007, 09:32 »
only if you have the later rear calipers, the early ones have the handbrake hose going into the top of the caliper.  In this case apparently you can flip the calipers upside down, problem with this is the bleed nipples will then be at the bottom so you';ll have to take em off and hang em the right way up again to bleed.
