Author Topic: mk1 golf gearbox  (Read 3593 times)
Offline daniel-1986
mk1 golf gearbox
« on: 04 October 2007, 21:12 »
my mate has not long bought a mk1 1.0 or 1.3 golf with a 4-speed gearbox and i was wondering if it will fit on to my mk2 1.3 4-speed golf as my input shaft bearing in on its way out. i dont want to bother gettin a 5-speed for mine for now since i want to save for a mk1 or mk2 gti
tomo320
Re: mk1 golf gearbox
« Reply #1 on: 04 October 2007, 23:53 »
yeah it will fit mate
Offline daniel-1986
« Reply #2 on: 05 October 2007, 14:54 »
cheers mate hopefully he'll giv it me on a cheep since he will be doin a conversion on his mk1
Offline daniel-1986
« Reply #3 on: 05 October 2007, 19:50 »
forgot to ask. does it matter about the difference in clutches
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #4 on: 18 November 2007, 13:18 »
i have a question, does the gti 1600 box fit a mk1 caddy 1600 diesel which has a 4 speed in it?
« Reply #5 on: 28 November 2007, 12:34 »
1) check the input shaft size on the new gearbox, it should match up with yours. Either way, just fit a new clutch to match the gearbox, crazy not to put a new clutch on while box is out!
2) Yes it will bolt up fine, not sure if the ratios will be any good though, the 1600 box is a very close ratio box so wont make the best of the 1600 diesel torque curve id have thought.  Only thing to check is the size of the driveshaft flanges, your diesel may have 100mm whereas the 1600 will be 90mm.  Also you'll need all the 5 speed linkages and even the stick itself IIRC to make it work (assuming the 1600 box is a 5 speeder)
« Last Edit: 28 November 2007, 12:36 by rubjonny »
