Author Topic: Oil Temp after Head Gasket Change  (Read 1284 times)
Offline mpgscott
« on: 04 March 2004, 23:48 »
Have just changed the head gasket on my 1990 8vgti all went well and head did not need skimming.
After putting back together and running for an hour or so the oil temp is sitting at about 94 degrees and I have not had the car over 60mph or 3500 rpm.
It always used to run at 88-90 degrees when running like this, has anyone any ideas.
All else seems ok.  Should I run the car gently for the first couple of hundred miles also after a head gasket change?
Thanks for any suggestions.
1996 VR6 Highline
2007 Aprillia Tuono
golfvr6
Re:Oil Temp after Head Gasket Change
« Reply #1 on: 05 March 2004, 00:00 »
Oil temp sounds fine to me. Don't worry about it.
Offline mpgscott
« Reply #2 on: 05 March 2004, 00:05 »
Thanks
Do you think I need to take it easy if so for how long?
1996 VR6 Highline
2007 Aprillia Tuono
golfvr6
« Reply #3 on: 05 March 2004, 00:09 »
Probably not, providing the job has been done properly with good parts, all should be ok.
