Author Topic: PLEASE,PLEASE HELP A DESPERATE MAN.  (Read 2257 times)
Offline samco-jack
« on: 04 March 2004, 23:44 »
Alright all.
              I know there,s already been a lot said about this in prevous post but i can't find one that applies to my problem so here it is.
                     When i turn the key on my mk golf gti 8v digi the idle fly's  up and revs between 3000 and up to4000 rpm.iv cleaned the isv i can feel it vibrating when the engines on,cleaned the entirer throttle body,there are no visable vacuum leaks i,v replaced all the vacuum hoses,checked that the gas pedel,s not sticking, even taped up other thing's like the dip stick just incase theres some leak there .I really need help i just don't know what to do?Please help a desperate man.
golfvr6
Re:PLEASE,PLEASE HELP A DESPERATE MAN.
« Reply #1 on: 05 March 2004, 00:02 »
Do the revs hold at that or do they drop back down?
Only when cold or all the time?
My first thoughts are a shagged ISV but if you can give more details then i will see if i can help.
turbo
« Reply #2 on: 05 March 2004, 00:09 »
my revs starting playing up the other day and guess what it was it was the throttle sensor wire this had snapped ive crimped it so many times.......
so this may be the problem on yours this detecs if the throttle is closed if the wire has broke then it thinks the throttle is open! tugg the wire slightly as it can snap inside the vw plastic sleeving! otherwise the wire looks ok...
« Last Edit: 05 March 2004, 00:09 by vwsystems »
Offline samco-jack
« Reply #3 on: 05 March 2004, 00:19 »
THE REVS STAY AT ABOUT 3000 TO 4000 ALWAYS.I HAD TO DRIVE IT TO WORK TODAY AND AT THE LIGHTS THEY WERE UP TO 4500.
golfvr6
« Reply #4 on: 05 March 2004, 00:20 »
Try disconnecting the ISV.
Offline samco-jack
« Reply #5 on: 05 March 2004, 00:24 »
IT JUST CUTS OUT
golfvr6
« Reply #6 on: 05 March 2004, 00:39 »
Go to a scrappy and find another ISV. I suspect this is your problem , if not then it must be a vacuum leak.
Offline richandhazel
« Reply #7 on: 05 March 2004, 04:16 »
Until you get another ISV, you may find that you can keep it disconnected and up the idle so it doesn't stall..........I'm sure it was Dizzie that did the same recently.
Alternatively, if you live nearby (Yateley), I have a spare ISV you could try.
Offline samco-jack
« Reply #8 on: 05 March 2004, 17:43 »
I'v found by dissconeting the coolant tempeature sensor and screwing the idle screw right out i can get it to idle at 1100.Does this give any one any clues to whats up.If this is going to be the best i can do until i get a ISV is this going to effect the car in any way?
« Reply #9 on: 05 March 2004, 18:10 »
I can't see how you'll do any great harm, just maybe less efficient, however I have to admit I'm not as up to speed on the in's and out's of the digifant fuel system.
If it were me I would make sure you have THOROUGHLY cleaned the ISV and throttle body, check your throttle valve switches and thoroughly check for vaccuum leaks. If the ISV is humming/vibrating then I would have thought that it is working, especially as the car stalled when you disconnected it.
Have you seen my write up on this:-
http://www.richandhazel.servebeer.com/gti/mk2/fuel/main.htm#ISV
