Author Topic: Gearbox Disaster-Please help (location of 5th gear linkage ?)  (Read 1801 times)
Offline new8vgtiowner
Can anyone please advise----After a long run (300 miles) doing approx 65 mph my 88 8v suddenly dropped out of 5th---when trying to re engauge a loud grinding noise like trying to do it with no clutch---(still have 1,2,3,4th and reverse,gearlever has been sloppy for a while and was thinking about a linkage rebuild kit---also now it sounds as though the release bearing is on its way out----very noisey until the clutch is depressed-------
So please---Is this a common problem ? (gti done 155 thou)
                 Will "any" gearbox fit ? as long as same year and 5 speed ( i think the gti cluch is larger-i have a spares 88 1.6)
                  Cost i am looking at for comp` clutch and gearbox (will put it in myself-the old girl is not going to die yet)
Thanks all-Petew Haynes.
« Last Edit: 02 October 2007, 23:03 by new8vgtiowner »
Offline rowlers
  • I'm back - MK7 GTI
Re: Gearbox Disaster-Please help
« Reply #1 on: 30 September 2007, 17:28 »
iirc loss of 5th is the first sign of low oil in gearboxtop it up see if tat helps
Offline Mew
« Reply #2 on: 30 September 2007, 17:31 »
Or could be a snapped linkage?
Offline Horney
« Reply #3 on: 30 September 2007, 18:07 »
Yeah I lost 5th when I ran out of gearbox oil in my old GTi.
Nick
« Reply #4 on: 30 September 2007, 18:47 »
Think i`ve found the problem-----is it called the "relay shaft" bush----should be ball/round type of bush ? well all i have left is a small amount of metal that looks like it once had splines on----moves about in the socket about an inch free movement !!!!!!!!!!
Offline BobbyT
« Reply #5 on: 01 October 2007, 08:06 »
happened twice to my mk1! your gear box is fooked mate! dont rebuild, try and get a new one!  :smiley:
Offline Gambit
« Reply #6 on: 01 October 2007, 09:21 »
see here
http://www.golfgtiforum.co.uk/index.php?topic=51321.0
« Reply #7 on: 01 October 2007, 20:21 »
Drained the "oil" out----only half litre !!!!! that was black----got new bush---refilled----same noise same problem----no 5th and sounds like relase bearing is screaming untill clutch depressed---so doing 1400 miles in 1 week was toooooo much then ?.
Where is best to get relacement box from -any ideas please ?-and cost ? Thanks all.
VeeDubGTI16v
Re: Gearbox Disaster-Please help (need new box now)
« Reply #8 on: 01 October 2007, 20:26 »
i have a 16v one for sale if your near guildford!
« Reply #9 on: 01 October 2007, 20:29 »
Sorry mate---in Germany (British Army) maybe was too much for it on the Autobahn----
