Golf mk2
compression test results high in one cylinder??????
Topic: compression test results high in one cylinder?????? (Read 915 times)
xrunner
Just got here
28 September 2007, 19:57 »
Has anyone ever seen 250 psi in one cylinder and 140-150 in the rest. I have a 1990 1.8L 8v, engine code ABS. Engine runs rough and sometimes I loose oil preasure after driving it hard. Thanks for any info.
Last Edit: 28 September 2007, 20:00 by xrunner
monzablue16v
Re: compression test results high in one cylinder??????
28 September 2007, 22:57 »
Sticky valves possibly it does seem wrong all should be near enough the same.
Quote from: AlanD on 24 October 2008, 13:33
Ben Lessani
The poor mans MK2 Haynes author
30 September 2007, 20:51 »
sure its not low in 3?
xrunner
Just got here
01 October 2007, 17:06 »
just did the test over. Now it is 200 psi on all 4
Golf mk2
