Author Topic: Drive shafts??  (Read 769 times)
Offline Teamheath
  • Mk2 Black Jetta
Drive shafts??
« on: 27 September 2007, 21:48 »
Just been looking at a Mk2 Jetta.  1.8 GL 8v i think.
Goes and stops alright, and the body is very tidy indeed.
But when driving it knocks from the front off side low down.  Could it be a loose drive shaft??  Or worn one??  And if it is is it easy enought to fix??
Many thanks.
Track Day Weapon - Mk2 Jetta GL??  Soon to be modded.....
Offline firstVW
Re: Drive shafts??
« Reply #1 on: 28 September 2007, 19:01 »
Ball joint maybe?
Offline Mk2Kezza
Re: Drive shafts??
« Reply #2 on: 28 September 2007, 20:25 »
Could be the CV joint. Do you hear it when on full lock?
<br />Almost finished.....
Offline Teamheath
  • Mk2 Black Jetta
Re: Drive shafts??
« Reply #3 on: 01 October 2007, 20:34 »
You can hear it all the time tbh, not just on full lock.  Def sounds like it knocks in time with a rotation of the wheel if that makes sence.
Could be the ball joint i spose tho.
Doesnt sound too nice and its a bit of a drive when i go pick it up so want to sort it straight away.
