Author Topic: STUPID ANOYING PROBLEM!! PLEASE HELP ME  (Read 610 times)
Offline gtiferg
« on: 27 September 2007, 17:26 »
Any help on this problem would be greatly apreciated....
My reverse lights are always on when the car is in neutral, and go off when in reverse or the gearstick is pushed over to the right (in neutral).
I have changed the reverse light switch thinkin this was the problem but it isnt, I have also replaced the plug that fits on top of the switch!
The car also suffers from a bad earthing somewhere as the battery drains in 24 hours.
Anys ideas before I kill myself!!!!!
Thanks
Offline DarnPB
  • Formerly Darnpistonbroke
Re: STUPID ANOYING PROBLEM!! PLEASE HELP ME
« Reply #1 on: 27 September 2007, 17:42 »
Your problems may not be related.
Check the condition of your battery first for the current drain problem. It may be FUBAR.
As for the reverse light, remove the block connecter in the boot from the light clusters and look at the terminals. If you see one very corroded, then the voltage will try and earth itself through the next easiest route. That is why sometimes when you are stuck behind an older car and they indicate, you get a mini light show. Same if they reverse or brake.
Clean the corroded terminal and plop a blob of solder on the corrosion damage. Blend off and refit. :cool:
Offline gtiferg
« Reply #2 on: 27 September 2007, 19:41 »
Thanks....i'll give that a go!
