Author Topic: windscreen washer problem  (Read 2453 times)
Offline spuddy333
« on: 03 March 2004, 15:31 »
please can some one help??
1991 golf cab only prob is cant get windscreen washer to pump water to screen ,the power is at the motor but it not working have tried a new one,same prob,if i but motor across 12v it works fine,whats going on!!!!
Re:windscreen washer problem
« Reply #1 on: 03 March 2004, 16:26 »
Have you checked the amount of voltage you are getting at the wires, possibly not enough to turn the motor?  Have you tried to run it without the pipes attached in case there is a blockage somewhere?
Offline lairy_1
« Reply #2 on: 10 March 2004, 12:56 »
Mine's just stopped working. I think mine is the stem on the steering column, as it doesn't set the wipers working three times when I try and wash the window.
1983 Mk1 G60
1990 Passat VR6
Offline bigkev750
« Reply #3 on: 11 March 2004, 21:55 »
i've seen a few cars with the same problem what usually happens is where the bonnet hinges are the pipe gets kinked over the years and collapses when closing the bonnet,try working the washers with the bonnet open if they work thats the problem but best to check the pipe in that area anyway
good luck ;)
Offline bigkev750
« Reply #4 on: 11 March 2004, 21:57 »
what happens when i get past the 50 post mark
(sorry to change  the subject) ;D ;D ???
Offline bigkev750
« Reply #5 on: 11 March 2004, 21:58 »
hey i am nearly there  :o :o
Offline bigkev750
« Reply #6 on: 11 March 2004, 22:00 »
mmmmm not very much happens apparently  :(
Offline bigkev750
« Reply #7 on: 11 March 2004, 22:02 »
oh well at least my windscreen washers work ;D
Offline benjam_in
« Reply #8 on: 22 March 2004, 16:47 »
Try cleaning up the connections on the washer motor! Mine didn't work when i got the car so changed the motor and it still didnt work. So cleaned up the connections and the old motor worked fine!
Golf Mk2 Gti 1988
