Author Topic: Mk2 2l 8v acceleration woes  (Read 1003 times)
Offline sporting wood
« on: 26 September 2007, 22:24 »
My car judders under accelerating from anywhere over 3500 -> 4000rpm in any gear. It also sounds louder than I'm sure it should but has just had a new middle and back box, any ideas?
Offline jimcub
  • hi it's red
Re: Mk2 2l 8v acceleration woes
« Reply #1 on: 26 September 2007, 23:48 »
Hi reading other posts the judder sounds like the maf or the ecu, the maf can be cleaned and the ecu reset by disconnecting the battery for 15 mins. But if you have an alarm you may have to reset that as well, also know your radio code.
I bought my daughter an 8v Mk3 gti and this has the same problem, I will attempt to fix this weekend.
Also I bought some new ign leads and it was like Blackpool illuminations sparks everywhere, so they will try and get some Bosch for me today.
play gets in the way of work
« Reply #2 on: 27 September 2007, 13:50 »
thanks mate, I'll give it a go and hope for the best!
