Author Topic: Intermitant faults  (Read 742 times)
Offline Grazer
Intermitant faults
« on: 26 September 2007, 21:51 »
Whilst driving home tonight, I the red warning light below the "Oil" icon on the dash began flashing.
Then after a few seconds, there was a buzzer sounding, which I guess is an audible warning too.
After checking the oil, everything appeared in order.
Is this a common fault?
mk 2 1.6 8v Driver
Offline Mew
Re: Intermitant faults
« Reply #1 on: 26 September 2007, 21:58 »
Where you going round a corner at the time?
Offline Grazer
« Reply #2 on: 26 September 2007, 22:07 »
No, on a straight section of road.  :sad:
Offline Philpy
« Reply #3 on: 27 September 2007, 11:21 »
Either low oil pressure  :cry: Or if your lucky a dodgy sensor or mine was actually a loose connection on the oil sensor
Offline Grazer
« Reply #4 on: 27 September 2007, 14:02 »
I still haven't had the time to give it the once over, check out all the connection and what not under the bonnet so, hopefully it's just a loose connection.
