Author Topic: side repeater help  (Read 977 times)
Offline jackass1989
side repeater help
« on: 26 September 2007, 19:01 »
i was just changeing my original side repeaters for smoked ones, and me being an idiot left the car with out the side repeater cover on, and the loom and bulb have falling into the side panel, is their any easy way to get to this , or is it a fact of getting something in the hole where the bulb comes out and having a fiddle to get it back out lol, cheers for any help.
Jack
Offline golf mk2 tornado red
  • same s**t just another day
Re: side repeater help
« Reply #1 on: 26 September 2007, 19:12 »
lol  ide ot  get a metal coat hanger and straiten it put a hook on the end and fiddle. a torch may be required
Offline monkeyalan
« Reply #2 on: 26 September 2007, 19:15 »
undo the wheel arch liner bolts and you should be able to reach it.
Offline Mew
« Reply #3 on: 26 September 2007, 19:25 »
Remove the plastic scuttle panel and you will see where the wire goes into the wing. Pull it out into the engine bay and tape a stick or something rigid to it and then look through the hole on the wing and aim for it! It can also help if you turn the indicators on as it is quite dark inside a wing.  :smiley:
Offline takethefifth
« Reply #4 on: 26 September 2007, 20:50 »
Arch liner bolts, you only need to undo a couple to bend it enough to get your hand in. I know cos i did the exact same thing fitting mine!  :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 26 September 2007, 23:27 »
Turn the flasher on so you can see it through the hole, reach in with a coathanger wire bent with a hook on the end and fish it out!
Tom
Offline jackass1989
« Reply #6 on: 27 September 2007, 19:25 »
cheers people, think ill do the old coathanger jobby if not ill try other things, cheers again
Offline Ben Lessani
« Reply #7 on: 27 September 2007, 21:25 »
Tom
2nd'ed - i've done this a tonne of times, had to cabletie the bugger in place in the end
