Another problem...my engine warning light came on the other day and stayed on. its not the EPC or whatever, its the one shaped like an engine, that the book describes as being an emissions warning light.
it had an MOT other week. the Temeperature gauge reasy 90deg, but decides to go to zero degrees when it pleases...although this happened before the engine light came on. getting on VAGCOM in next week or so. anyone shed any light as to common things? also, i replced the DV the other week, but again, the engine light came on way after replacing this. no obvious leaks. Engine seems to run ok. ever so slghtly lumpy at idle, but nothing untoward as such...acceleration can seem a little inconcistent in that if you just tickle the throttle it seems to want to go...boot it and doesn't feel as good by far. when you tickle it or boot it right after starting, seems to be great, then warms up and doesnt pull as much as i expect. pulls well in 5th from 70, so may just be illusion, however may be linked?
ANY help aprreciated. its a 2000 (X reg) 1.8 turbo by the way
