Author Topic: taking off side skirts??  (Read 2290 times)
Offline BobbyT
« on: 23 September 2007, 10:01 »
how do you take the cabby side skirts off? i want to take them off and see if there is any rust that needs sorting!  :undecided:
tomo320
Re: taking off side skirts??
« Reply #1 on: 24 September 2007, 23:53 »
that big bar rob :smiley:
Offline BobbyT
« Reply #2 on: 25 September 2007, 00:02 »
wont that break the clips? do you just pull them then?  :smiley:
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #3 on: 25 September 2007, 20:57 »
VW in all their wisdom ? decided to stick on there body kits, a few screws here and there, but mostly super sticky glue.
3 options,
Steam cleaner on basta*d hot mode, softes the glue quickly, allowing you to gently pull them off.
Boiling water, same as above, but slower & kinder to the paint work.
Hot air gun, same again, except you run the risk of melting the paint/plastic.
kraM
It's not the speed... it's the sudden stops...
Offline BobbyT
« Reply #4 on: 25 September 2007, 21:08 »
bugger! sounds like a right faf! just wanted to get a good look at the sills!!  :angry:
