Author Topic: mk2 golf driveshafts  (Read 846 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« on: 22 September 2007, 19:35 »
does any mk2 driveshaft fit a mk2 gti or do i need gti ones
i need to replace one and i found a solid one on a mk2 ryder
but i dont want to buy it incase it does not fit
Offline Mk2Kezza
Re: mk2 golf driveshafts
« Reply #1 on: 22 September 2007, 20:46 »
I think that the drive shafts are different sizes unfortunately. The diameter of the end of the shaft that joins to the gearbox is 100mm on GTi's and 90mm on selected diesels and drivers.
Thats what you'll have to measure.
http://www.scirocco.org/gears/
Try the above for the gearbox codes, and what size flange they have, although that particular site doesn't give the engines codes to match to the box. So on your trip to your scrappy you need to checc the box code which is located on the bell housing of the box.
Good luck  :smiley:
<br />Almost finished.....
Offline VR6_ROB
« Reply #2 on: 22 September 2007, 20:52 »
ah nice one ill check them out thanks for the info
