Author Topic: fuel leak  (Read 707 times)
Offline tri
fuel leak
« on: 21 September 2007, 21:22 »
Hey I had a quick look but couldn’t see anything so I’ve got to ask. I have a leak at the fuel pump at the back of the car (MK II digi 8v) It seams to be leaking from the retaining clip and the main box. I took the pump out and put new o rings in and its not really helped to much its turned from a small run (if wiped it would be just as bad almost straight away) into a small drip(it take a few seconds to return) my question how do you stop it I’ve done all the things I can think off.
Cheers Tri
Offline monkeyalan
Re: fuel leak
« Reply #1 on: 22 September 2007, 10:17 »
mine was leaking from a crack in the top of the reservior so I bought a new one from GSF. they're not that expensive , £15 ish IIRC.
Offline tri
Re: fuel leak
« Reply #2 on: 22 September 2007, 14:24 »
hey thanks for the reply i have the same problem that i just couldn't see only took me 5 atempts (thats putting it back in the car as well) Gsf said they didn't stock them so had to got to VW which cost me 30
Offline monkeyalan
Re: fuel leak
« Reply #3 on: 22 September 2007, 14:57 »
still , £30 ain't too bad. you'll probably save that in petrol in a month!   :smiley:
Offline tri
Re: fuel leak
« Reply #4 on: 22 September 2007, 19:21 »
true i not that bothered about the 30 just glad its finally done would pay lot more to know my cars safe and still running
