I've already answered this in detail in another thread. I've even posted links [or did I do all this on Tyresmoke?].
It's a spacer which makes the whooshy noises and not the DV. The Forge DV will not damage anything - Quite the contrary, it will better protect the turbo by not failing like the stock DV is known to do. VW have relocated the stock DV to the front to help the problem but apparently there are still stock DV failures - It's a known weak link.
It's primarily a precautionary measure, especially on a remapped car, but it does hold boost longer (by a very small amount).
The Forge DV has been very thoroughly tested and there is also a version for the Ed30.
