Author Topic: Changing CV joint  (Read 6775 times)
Offline Tim1111
Changing CV joint
« on: 19 September 2007, 13:47 »
I need to change the RH outer CV joint on the mk3 GTi.
A friend has offered to help me (or rather do it for me) if I pick up all the bits needed (since I'm not the most experienced mechanic).
Just thought I'd check on here that I've got everything I need before I pop down to GSF for the parts.
The parts I believe I need:
Outer CV joint kit
Boot kit
CV joint grease
New hub nut
1) Is there anything else I need?
2) Would anyone advise changing the inner boot whilst the driveshafts off?
3) The Haynes Manual states the use of a new circlip.  Does this come in the joint kit?
4) Do I need to change the gearbox oil while I'm there?  I'm sure someone mentioned I'd have to do this if I'm removing the driveshaft (but the haynes manual doesn't mention it).
5) I read somewhere about the cv bolt sockets not being torx.  I'm assuming my mate won't have the correct socket, and GSF website lists two - the M8 and M10.  Any ideas which one I'll need?
Sorry for all the questions, but I need to get the car back on the road asap!
Tim.
« Last Edit: 19 September 2007, 14:11 by Tim1111 »
Offline boneybradley
  • Back in a Mk3...
Re: Changing CV joint
« Reply #1 on: 19 September 2007, 17:19 »
Outer CV joint kit
Boot kit
CV joint grease
New hub nut
Tim.
the cv joint kit should include the hub nut and the circlip (gkn one's do)..the boot kit should include the grease
1.that sounds all
2. the inner boot will be much easier and it's worth changing if it's in poor nick
3. circlip in the cv joint kit
4. No need to change the box oil
5. I am sure the 020 box has m10 torx bolts...but don't hold me to that
Offline Tim1111
« Reply #2 on: 19 September 2007, 19:06 »
Thanks mate.
I'll pick up an inner boot and do that whilst I'm there.  Might as well for the sake of a about £8.
Offline Tim1111
« Reply #3 on: 19 September 2007, 19:41 »
Sorry one more thing.
The hub nut in the joint kit is a 12 point nut.  Yet looking on the draper tools website it recommends using a 6 point socket for vw hub nuts:
http://www.drapertools.com/b2c/b2citmdsp.pgm?pp_skmno=35521
Is this correct or do I need the bi-hexagon socket:
http://www.drapertools.com/b2c/b2citmdsp.pgm?pp_skmno=24765
Sorry if this sounds stupid, but I want to get all the bits needed to get the job done in one session.
Thanks
Tim.
  • Back in a Mk3...
« Reply #4 on: 19 September 2007, 20:01 »
I've never used special sockets for the hub nut's.... normally it's what ever I have!! and last time i did vw it was a 32mm basic socket
Offline Len
« Reply #5 on: 19 September 2007, 20:21 »
And you will need a long lever bar to undo the hub nut!
www.sas.org.uk
www.the-ace.org.uk
Offline Tim1111
« Reply #6 on: 19 September 2007, 21:03 »
Excellent, thanks all.
I'll use what i've got then.
