Golf mk2
Sticky Clutch-? Please advise
Topic: Sticky Clutch-? Please advise (Read 943 times)
new8vgtiowner
17 September 2007, 20:52 »
Hello all-just managed after many years to get hold of a smart 88 gti-----problem is-----sometimes the clutch pedal stays down and slowly rises,is this a common problem ? do you think just a sticky cable or new clutch req ?----no other problems at all--With thanks pete.
Uruk Hai
Re: Sticky Clutch-? Please advise
17 September 2007, 21:47 »
Might be the pressure plate wearing out but you could take the clutch cable off to see how freely it runs through the sleeve its in. I hung mine up in the garage and poured oil down through the sleeve and now its nice and smooooooooth
Chris-White
Manufactured in Germany. Ruined in Britain.
18 September 2007, 03:29 »
clutch release bearing / arm maybe? the little arm can crack and cause these symptoms afaik.
http://www.brokevw.com/releasearm.html
OakeyDoak16v
18 September 2007, 12:02 »
Yeah, I just replaced the clutch release arm on mine as it was causing probs, then cracked. Worth having it checked though while you can still drive it to a garage. I paid aboit £80 to have mine replaced. Hope this helps you.
new8vgtiowner
18 September 2007, 19:07 »
Cheers all-removed cable today,hung it up sprayed some magic (wd40) through it and replaced --and working fine now-had no idea just a sticky cable could cause so much grief----!! Thanks.
Uruk Hai
18 September 2007, 19:09 »
Your welcome
monzablue16v
Reply #6 on:
18 September 2007, 23:20 »
New cable isn't too much, WD won't fix it forever
Quote from: AlanD on 24 October 2008, 13:33
Golf mk2
