Author Topic: where is the MAF?  (Read 919 times)
Offline paultownsend
where is the MAF?
« on: 17 September 2007, 01:14 »
according to rubjonnys mk2 tuning advice, where is the MAF?
i know how to adjust the idle on the throttle body, but where do i adjust the co?
pics would be good
Paul
Offline DarnPB
  • Formerly Darnpistonbroke
Re: where is the MAF?
« Reply #1 on: 17 September 2007, 04:18 »
The MAF is located in the air filter housing. Look at the air filter box and you will see a plug with wires connected. That is the Mass Airflow sensor. In the top will be a drilling. This should be capped. Prize the cap off and in the hole will be an allen keyed plug. That is what you adjust for the CO. :wink:
« Reply #2 on: 17 September 2007, 10:13 »
ah you mean the AFM !
Offline DarnPB
« Reply #3 on: 17 September 2007, 11:56 »
If you like. Mas Air Flow. Air Flow Meter. One and the same.
« Reply #4 on: 17 September 2007, 12:20 »
if the co is set high what effect does this have on the engine? i had perfect idle before so didnt need adjusting, but co mixture was turned down (clockwise) and the car was definately slower! passed emissions 9 months ago perfectly!
Offline DarnPB
« Reply #5 on: 17 September 2007, 13:16 »
I had a massive problem with my CO content. It was up to 9.45. This was caused my the ECU being chipped badly before I owned the car. The result was that it drank fuel, and spat alot of it out of the exhaust, and caused compression problems by glazing the cylinder walls. I had to remove the head, sump and pistons to replace the rings and service the cylinders. I also gave the head a skim and service too.
I replaced the ECU after more trouble shooting and now I have a very powerfull 8v which I'm very pleased with.
High emissions will not effect idle if the idle is set to match the mixture. To set up the engine properly, first you need to check and set the ignition timing. This must be done first. Then you need a CO gas analiser (Spelling?? :sad:) and set the mixture and idle at the same time as per the imfamous guide. The reading should be between 1.0-1.5, but generally it is set at 2.0-2.5. The limit is 3.5. As you can see, mine was off the richter scale, but now its down to 1.2.
Actually, today I am going to re-adjust mine as when the aircon is on, the revs faid away to a stall.
Hope this helps. :smiley:
« Reply #6 on: 18 September 2007, 00:36 »
iv a friend with a co meter so il have a play! cheers
