Interestingly , they also state that they tested the OE 18 inch with Bridgestones RE050-A and they were WORSE!!! 2.5 sec a lap slower than 17's tested above.
Not unheard of. We run a control yokohama semi-slick tyre (A048R), and unless you have a heavy car (Say 1500kg or more) the the lower profiles just don't work. Not enough flex in the sidewall, resulting in poor drive.
We changed from 215x45x17 to 225x50x16, and gained 2 seconds a lap.
So lower profile is not always the way to go. In most cases the only benefit fit is the ability to fit bigger brakes.
But 18" wheels do look good on a GTI
