Author Topic: just bought a wee red sportline gti convertible..got a wee issue.....  (Read 1246 times)
Offline rabskyline
its a bit smokey after its warmed up...not when cold though....sounds back to front to me ? other than that its fine...been painted (wrong stripe on and alloys on it too ) at some point but very good job so not bothered as it is 15 year old !
Offline herbster
Hi, try a different oil or change it to see how it goes, cold oil is more sludgey less likely to burn etc, so if you use a higher spec oil you may rid this smoke? Check the breathers too, if they are restricted it can create a bit of crankcase pressure which can push oil where you don't want it. Hope this helps  :smiley:
FAB is my life and the CABRIO's the wifes!!!!
Offline rabskyline
cheers will do ! :cool:
Offline Sukhi
I would certainly do the above - after that, it may be worth checking the compression on all 4 cylinders if you have no joy.
Sukhi.
Ambika is the word
