Author Topic: accelarator cable has come off back of accelerator pedal  (Read 707 times)
Offline MK2 GTI REP
is this hard to put back on iv looked for the cable and if anything it looks akward.you dont need to take dash or anything out do you? wb asap thanks
Offline DarnPB
  • Formerly Darnpistonbroke
Re: accelarator cable has come off back of accelerator pedal
« Reply #1 on: 12 September 2007, 14:40 »
This happened to me, twice in a week. Fiddly job to put back on but you only need remove the undercover. I ended up using wire locking to keep the damn thing in place after the last time. In heavy but moving traffic, in the outside lane, raining, at daybreak heading into Madrid. Bit of a dodgem car ride coast to the side. :shocked:
Offline MK2 GTI REP
« Reply #2 on: 12 September 2007, 15:03 »
cheers i have a go at it now let u no how it goes
Offline MK2 GTI REP
« Reply #3 on: 12 September 2007, 15:59 »
ok got cable back on and car is now revving to 3000rpm by its self will greasiing cable help?
Offline DarnPB
« Reply #4 on: 12 September 2007, 17:13 »
Check where the cable disapears through the bulkhead. Sounds like something has hooked up.
Or the reason why it came off in the first place may be because it has started to seize. New one called for me thinks. You can try lubing it, but as the sheath is teflon lined, use only silicone grease. I don't think it will last long though as the inner cable will have carved itself a nice little channel in the lining and that is where it will be sticking.
