Author Topic: How to set co on mk2 8v  (Read 3336 times)
Offline Slimmedmk2
  • Slammedmk2`s Back!
« on: 28 February 2004, 17:03 »
Hello,my 91 8v has just failed mot on co level being too high.Where do you adjust it??have never done before so dont know where to look
Offline mk1
Re:How to set co on mk2 8v
« Reply #1 on: 28 February 2004, 17:23 »
There is a allen key adjustment screw in the air flow meter. Screw out to weaken the mixture, you need a gas analiser to set the mixture properly but you can guess by screwing out untill the idle starts to get rough, then in slowly untill a smooth idle is reached. When it goes back for mot, check the emissions, aim for 1.5% to 2% co.
Steve.
Offline richandhazel
« Reply #2 on: 28 February 2004, 17:42 »
Not a lot to add to Steve's reply there other than, the allan key size you need is 3mm and it will need to be reasonably long.
You're looking for an approximately 5mm dia tube sticking up from you air flow meter......allan key goes in there. What ever you do, don't rev the car with the allan key in there......otherwise you will damage the metering unit.
When was the last time you changed the air filter? If its an old one thats quite clogged, that can cause your CO to rise........not too mention poor performance.
« Last Edit: 28 February 2004, 17:46 by richandhazel »
Offline Slimmedmk2
« Reply #3 on: 28 February 2004, 17:47 »
cheers for the replies
Offline mk1
« Reply #4 on: 28 February 2004, 17:50 »
Hey Rich, it's a '91 so should have digi. No need to remove allen key, can't remember the size, 6mm ???.
Steve.
« Reply #5 on: 28 February 2004, 17:56 »
Ah yes..........I was in k-jet mode, but you're right, it should be a digifant, in which case ignore my post other than the air filter bit ::)
Offline Slimmedmk2
« Reply #6 on: 28 February 2004, 22:58 »
Thanks again for the replies,the air filter is a k+n panel filter so is ok as is only a couple of months old.It was quite good,all the blokes from the garage were having a good look at the car saying how clean it is. :)
