Golf mk2
Possible engine / gearbox mount gone? Mk2 16v
Topic: Possible engine / gearbox mount gone? Mk2 16v (Read 5701 times)
topbloke77
10 September 2007, 19:56 »
I have a 1989 mk2 16v. After a thrashing at Knockhill a judder/knock from the engine/box has appeared It appears from a standing start and when accelarating on/off. Im thinking it has to be a engine or gearbox mount. I have checked by trying to move the engine in the bay by hand, but it feels quite solid. Does anyone know what is the most likely mount to give up? Or any other suggestions as to what this could be?
Ian
£500 Wondercar! MkII 16V
dubvrs
GTI forum regular
Re: Possible engine / gearbox mount gone? Mk2 16v
10 September 2007, 20:30 »
Normaly it's the front engine mount. Mine was shot and as you say i could hardly move the engine. I did replace all 3 engine mounts when i put my 9a in and much better now.
Lewy
10 September 2007, 22:10 »
Start the car up and whilst in 1st (with h/brake on) release the clutch until just after biting point, and if you can see the engine move more than you think it should, or if you hear the tell-tale clunk - it's the front mount.
topbloke77
11 September 2007, 20:53 »
Thanks....
I will try this method for checking the mounts
adam_mk2
13 September 2007, 00:33 »
i have the same problem, going to look at it tommorow, hopefully it is the engine mount, mine also does it when i bring the clutch up when changing gear or is this something different? please let me know, thanks
Chris-White
Manufactured in Germany. Ruined in Britain.
13 September 2007, 01:55 »
Get a solid front mount, you wont look back imo.
Lewy
Reply #6 on:
13 September 2007, 08:17 »
Quote from: chris_wht on 13 September 2007, 01:55
Oh yes you will!
Mine is coming off when I bet the Milltek manifold with the flexi, as the vibration is f**kcing awfull.
Mew
Reply #7 on:
13 September 2007, 11:30 »
From my experience solid front mounts seem to be a bit hit and miss.
The first one i had in my 8v does shake the sh!t out of the car, like Lewy has said. Going off that i wouldn't recommend them
The one i have now though in a 16v is hardly noticeable, and that honestly isn't an exaggeration! Going off this one i would recommend one
I think the one in Chris' Jetta is somewhere in the middle of those 2
rowlers
I'm back - MK7 GTI
Reply #8 on:
13 September 2007, 18:11 »
mine is sweet, a kick when it starts, then no noticable extra vibration at all!
Mr Blue
Forum addict
Reply #9 on:
23 September 2007, 21:55 »
How easy are the rear engine mounts to change?
I know you need to support the engine blaa blaa but are they easy to get at?
Golf mk2
