Author Topic: Dizzy cap  (Read 893 times)
Offline firstVW
Dizzy cap
« on: 10 September 2007, 18:46 »
Hello all,
Iv got a missfire and decided its the dizzy cap and rotor arm that need replacing, problem is i ordered some and theyre too big. :sad: I think theres 2 set ups, a bosch one and something else. Im guessing mine isnt bosch as the bosch ones dont fit. Any ideas on the other one or some part numbers would be great!
Its a 1989 1.6 driver
Cheers peeps!
Offline e11ie
Re: Dizzy cap
« Reply #1 on: 10 September 2007, 19:40 »
Isn't there a part number on the dizzy that's on your car?
Offline firstVW
Re: Dizzy cap
« Reply #2 on: 18 September 2007, 10:38 »
No part number on dizzy but got that sorted now thanks. Well i say sorted, i got the right cap and rotor arm and still got the same probs with the missfire! A mate reckons it could be a blown valve. The cars been off the road for 2 long now and is my only form of transport, i need help! Has anybody had similar probs before? Just to re-cap, it sounds like a small plane when it does run, revs go up in blocks, has about half the power and unless im reving it it stalls.  :angry:
Offline firstVW
Re: Dizzy cap
« Reply #3 on: 26 September 2007, 19:19 »
Took the distributor top off and found a magnet from somewhere stuck inside it. Take out the magnet and problem solved. Next problem, what the fu#k was the magnet for?
Thanks
Offline Truesaint86
Re: Dizzy cap
« Reply #4 on: 27 September 2007, 19:11 »
did this cure the noise and the lack of power aswell?
Offline firstVW
Re: Dizzy cap
« Reply #5 on: 28 September 2007, 18:33 »
Yeah it did mate. But last night it started being a bit lumpy below 2000 revs :huh:
