Author Topic: Golf GT TDI 150 or GT TDI 130 vs Seat Leon 130 or 150  (Read 10920 times)
Offline Red_Stafford
« on: 10 September 2007, 13:52 »
Hi all I want one of the above cars for my next car, I currently have a Pug 306 TD and it is just too slow and old now and I want to upgrade, so which ones it to be ?? can you guys give me the pros & cons between these cars.
Offline Ridg
  • TDI - Soot Happens!
Re: Golf GT TDI 150 or GT TDI 130 vs Seat Leon 130 or 150
« Reply #1 on: 10 September 2007, 14:22 »
not sure if you already know but the MK1 leon is the basically a MK4 golf with a body kit.
the only think i know about differences between the leon and golf are that the leon weights more, so slower and less economical, however its cheaper / you might get more options for your money.
one thing i found when i was looking for my car last year was that the leon TDI 150 is a rare car, my golf took searching to find, but there were less leons.
Oh the leons are 5 dr only (can be a problem for some) personally i think both the Golf and Leon 5 dr's look good, where as the A3 doesn't
I'd imagine that the leons suffer the same problems as the golfs which you can find in a sticky.
pro's wise, solidly build, very good performance from a diesel whilst still returning over 50 mpg.
you get a good standard spec from both the 130 and 150, the 150 gives you the 1.8T suspension a front mounted intercooler and bigger turbo, you also get the V6 4 motion front spliter  :cool: heres a fooked up think the 130 gets the front arm rest as standard in the 150 its a £110 option  :shocked:
« Reply #2 on: 10 September 2007, 15:02 »
I have heard that the Leons have better handling ? Also I didnt think the was any difference between the GT TDI130 & 150 cosmenticly I just thought it had a FMIC I thought this was the only difference plus the extra 20bhp
Offline Rhyso
« Reply #3 on: 10 September 2007, 15:12 »
also i think the 150 came with the Montreal II wheels as standard.  Ridge is correct on the other things too :afro:
Offline Ridg
« Reply #4 on: 10 September 2007, 15:13 »
unless seat have tweaked the suspension setup i'd image they would handle the same as its the same chassis, can't really comment on the handly as not driven a leon.
from the outside the 150 sits lower (1.8T suspension) and has the different splitter, other than that they are the same as far as i know, both had monty II's
« Reply #5 on: 10 September 2007, 15:51 »
What is the handling like on the GT TDI150 because I have heard it is not that good.
Offline Rhyso
« Reply #6 on: 10 September 2007, 15:58 »
sadly the MKIV chassis was not the greatest platform for a GTI but with a couple of mods in can be turned into a decent car.
with the TDI the nose is obviously heavier than the petrol equivalent so you will get understeer; fitting a rear anti-roll bar will help reduce that but won't eliminate it completely.
Offline Ridg
« Reply #7 on: 10 September 2007, 16:19 »
the 150 is slightly heavier than the 130 which like Rhyso says can lean to understeer.  i've not had any problems with the handling on mine, but i don't trash it that often, but when i have i've found the handling ok, obviously its not an elise but as long as you're not stupid you'll be fine.
Offline gooseuk
  • Diesel is the way forward
« Reply #8 on: 13 September 2007, 13:05 »
I wanted the leon 130 but had a hard time finding one in the price bracket. I say go for leon if you can find them.
Diesel power all the way
Offline RandomJord
« Reply #9 on: 17 September 2007, 11:13 »
Yeah, the Leons are wicked, they do handle better as its got a different suspension set up, the 130 TDI SE is a great car for the money, as is the Cupra 150 if youve got a bit more to spend. id buy one over a golf anyday to be fair!
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
