Author Topic: alternator light  (Read 894 times)
Offline sesterfield
alternator light
« on: 09 September 2007, 22:32 »
I changed the water pump on my car this weekend, and in doing so removed the alternator.  Now everythings back together I've noticed that the battery light doesn't come on when I start the car anymore.  I have checked the blue wire and it seems ok, I put everything back as it was so am puzzled as to why it's not working anymore!
Any help would be great!
Offline Mr Blue
Re: alternator light
« Reply #1 on: 09 September 2007, 23:32 »
the battery light shouldnt be on :huh:
you must have had a loose belt and then fixed the problem when you adjusted it :laugh:
Offline sesterfield
« Reply #2 on: 10 September 2007, 07:49 »
I mean it doesn't flash when the key is turned anymore, its just off the entire time!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #3 on: 10 September 2007, 08:06 »
check the blue wire from dash to alternator, usually connected by the battery, thats the charging light, atm yo probably dont have anything being put out, id check the voltages with and without the car running to be sure!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Davo13
« Reply #4 on: 10 September 2007, 12:26 »
What car do you have in might answer the next question?
Why did you remove the alternator to change the the Water Pump?
Offline sesterfield
« Reply #5 on: 10 September 2007, 18:44 »
Mk2 16v
The wire seems fine, exactly as I found it!
