Author Topic: Mk1 golf rust cure & help needed  (Read 2615 times)
Offline jamadz
« on: 09 September 2007, 10:16 »
Hi All
My first post on here, so be nice :)
I've recently been cleaning up all the rust on the floor pans, I've taken mostly everything back to the bare metal, and have had all the holes welded,
Could anyone recomend a rust cure to put on before i prime and paint it?
ive used very small amounts of "Krust" in the past on small rust spots, however as this is a large area would probably need something different.
Cheers for the help in advance
adz :)
Offline Gil7130
Re: Mk1 golf rust cure & help needed
« Reply #1 on: 09 September 2007, 12:50 »
Por-15 does a pretty good job, i've used it on my old porka, basically all the floorpans and inner wings, really bloody hard work stripping of the ld underseal, then re sealed with 3m spayable sealer, only the inner wings not the floors, I just left the Por15 on them.
Its tought stuff.
http://www.frost.co.uk/productList.asp?catID=28&frostCat=Rust&subcatID=37&frostSubCat=POR-15
Make sure you use the metal ready as well before applying, as this kinda etch primes the metal for the por-15 paint to stick to, oh and don't get por15 on your hands either it takes weeks to come off.
Good luck  :smiley:
Offline jamadz
« Reply #2 on: 17 September 2007, 14:07 »
all sorted, my pc has been down so couldnt get your answer thankyou anyway
in the end after llots of hours taking it back to bare metal and getting the whelding done
i used hamerite rust remover worked ok ish gladd i got most the rust out
then etched and primed with anti rust primer
just gotta do the top coat, shes solid now
cheers Adz
